Need help with box :/
Tjwubs34
Honestly it seems like putting 3000 watts worth of subs in a box with only 3/4" walls seems a little sketchy to me. I would double layer the entire box to make sure it's as solid as possible. There is no such thing as building a box that's too strong.
If planning for the future, it would be nice to drop a big amp in there some day without a whole bunch of changes.
Pioneer 80PRS
Hey guys thanks u very much for your input. I went with his specs they look great!!!! I have 1/2" thick threaded rod for bracing I plan to go through the port all the way out the side of the box. Also from top to bottom. I have a total of 8 washers and 8 nuts. With a 1.5" thick top baffle. I hope to got this sounds good..... I have never ever top mounted subs
I got the box put together and the port height doesn't touch the top of box :( there's like a finger room :( it's 11.75" tall
This should be the cutsheet for the Torres above, hopefully you will find the error:
Fb = 31 Hz
Vb = 3 ft^3
External Height = 14 in
External Width = 40 in
External Depth = 20 in
Port Width = 4 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 40 x 20
Left & Right Sides =
Side 1 = 18 1/2 x 11 3/4
Side 2 = 19 1/4 x 11 3/4
Front = 34 7/8 x 11 3/4
Back = 40 x 11 3/4
L Port Internal Assembly Parts:
Front to Back = 14 1/8 x 11 3/4
Extension = 20 x 11 3/4
Can you post a picture of what you have? If the box is 12.5 tall internally your net volume probably came out higher than intended.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 992 Guests (See full list)
