CAD projects
So I've got a class that is Solidworks based. I have a project I need to do like asap that is a real world project.
Meaning it should some some type of problem. Can you guys give me some ideas to make in the next day or two? Some examples were like a glasses case, a handle for a pop bottle. Something like that. Nothing to complex.
I've got one idea that would incorporate a single din HU, volt meter, temp meter if chosen, and switches. A case to house it all for burp cars in other words. But that might be a bit to much right now.
So throw some ideas out for me to deaign of some small annoying problems you guys may have everyday.
Now the next one is a huge final design project.
Needs multiple parts that I can assemble, stuff that is swept thru curves, words embossed into it somewhere, complex stuff like that. Not doing a sub or amp. But throw out some other ideas like that if you guys want also. Make it hard.
If you want, pm me if you have your own personal project and I'll be more than happy to help if you are willing to let me use it for this if it will work as well. I would like to make this something I can 3d print in small scale to have a visual of it. But let me know guys. Thanks.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Maybe a small box for a small sub? Like for a computer or portable setup? Someone on here 3d printed a small box.
Pioneer 80PRS
If you need any help with solidworks let me know. I am an engineer and have been using solidworks for 6 years now.
I am by no means amazing at it but I am getting good enough to do surfacing and other complex geometries now.
With that being said I have done. Alt brackets, braces for boxes, and amp racks all while I was at work.
Any projects u guys want done and have dimensions for? Or give me a few simple ideas that I don't have to go measure a bunch. This is due tomorrow btw. I dropped the ball. Between solid works and inventor I can do most things. Bout 7 years of non work experience.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Get me the card so I can take the dimensions. :P
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
ended up designing a little box for a pair of dayton refeernce 4" full ranges. ill use parts off parts express and 18650s for power if i deside to built it.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
