running tweeter off headunit
justin0943
2 hours ago, dolarbilz said:
Nice find, maybe run two sets if you can manage to fit them..
But I would rather run a single 6.5 set over single 5.25 set.
so is it wroth twice the price to run 6.5 at $119 then 5.25 $50
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Depends on what your goals and budget are.
the goal is to replace the rf 6.75 coaxial speaker because I have to change the setting every time I turn on the subs because if I don't speakers sounds crappy at vol 20 out of 30 which I tune everything to and plus a little extra bass in the door so is the 6.5 worth twice as much or will 5.25 sound the same for half the price I may do a video showing the difference in the sound on the different setting
2 sundown sd-2 d4
flex tech
box design by Joe X
Ya then its worth the $110 to replace it sounds like.
my question after the last few posts.  is volume 30 still clean power?  what are your crossover settings at?  not that adding that punch amp and a new set of comps is a bad idea but is it needed?  wound the punch amp run the rf's well enough?  i mean really components are so much nicer but you mentions hospital and pawn shop in the same message.  so budget is for sure a thing your watching out for.  not like that is a bad thing.  no i'm just rambling.  been down the hospital road too many times. blah blah blah
yes that full tilt for my system I think the hu goes to 50 not for sure, when running the subs everything flat and hp filter have to set it at 50hz I think, with this setup the doors speakers has no bass just vocal which I don't mind with the subs on its the hassle changing the setting back to where it was so when the windows are up I can have some mid which isn't much in the doors because I can only go 20 on volume before it sounds like poop. as for the amp I was looking for a Microsoft pro tablet then looked around and seen the amp for cheap and bought it and was looking around on the web for components and saw the 5.25 for half price compare to the 6.5 ,for $50 i can handle that but if its worth getting the 6.5 then I'll save up to get them
2 sundown sd-2 d4
flex tech
box design by Joe X
i'n not familiar with the CT stuff.  but i know my DD 6.5's are nicer then the 5.25's i had.  though i wish i had my 5.25's back to run with my 6.5 mid bass drivers.  if that all makes sense.
if your wanting more mid response i suggest getting a dedicated driver for that.  maybe run it from 63-250/300  then the 5.25 comps active from 200 up.
  • Who's Online   0 Members, 0 Anonymous, 1081 Guests (See full list)
