running tweeter off headunit
justin0943
planning on getting CT Sounds Strato 6.5 Component Set with tweeters was thinking instead of buying a 4-channle amp was thinking getting 200 watt 2 channel amp to run the mid, and use the crossover that comes with the set an run the tweeter from the head unit that should be plenty of power for the tweeter not going for professional sound or anything just want a good sound and mid bump good
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
like dolarbilz said if you're going to utilize the passive network for the tweeter you may as well install them correctly with the mid driver. no reason to to twice the work for half the quality.
  • 5 weeks later...
On 11/23/2016 at 10:54 PM, dolarbilz said:
What two channel was you getting out of curiosity
sorry for the late post been in and out of the hospital just pick up a rf punch p200.2 for cheap at a pawn shop tested it on a home stereo system 1 mid and 1 tweeter on each channel it sounded amazing know just need to get the components and throw it on the truck
2 sundown sd-2 d4
flex tech
box design by Joe X
Right on man, keep us posted how you set them up and give us a review. Tuned in.
another question I've seen on their site CT Sounds Strato 5.25 is half the price then the 6.5 will their be a big difference between the 2 if not then Im getting the 5.25 for half the price
2 sundown sd-2 d4
flex tech
box design by Joe X
Have you checked out the meso 5.25 set? They are the next level up. $69.99
https://www.ct-sounds.com/products/speakers/meso-series/meso-5-25-component-set.html
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1092 Guests (See full list)
