s5300 Posted November 25, 2016 Report Posted November 25, 2016 Hello all! I'm finally in the financial threshold to get my first setup, after a year of lurking here and then however long my account has been made of slightly posting.. But the time has come, and I am ready. Anyways, car is a 2006 Lincoln Zephyr, think any MKZ, or better yet any 4 door sedan. I've been going to get a pair of Fi BL 12's. However, the FiDay 15's are out. I've had this discussion before for some larger 15's, but the clearance on the FiDay's is pretty small. - Would it be a bad idea to put two of these FiDay 15's in a ported enclosure in the back of a 4 door sedan? - The BL 12's would be great right now.. but I could have a completely solid setup with these 2 15's if they would be efficient in that space. Here is a link to album of dimensions if needed. http://imgur.com/a/ZXN6h THANKS GUYS!
twalker182 Posted November 25, 2016 Report Posted November 25, 2016 Misread your first message.....I would say (2) 15s would be louder than (1) 12. 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12"
Joe X Posted November 25, 2016 Report Posted November 25, 2016 With the dimensions you provide for your vehicle it looks like you could do two 15s rather easy. Two 15s for a trunk car is a great setup.
s5300 Posted November 25, 2016 Author Report Posted November 25, 2016 With the dimensions you provide for your vehicle it looks like you could do two 15s rather easy. Two 15s for a trunk car is a great setup. I don't mean to in any way insult your intelligence as I know you're one of the flyest motherfuckers around when it comes to this, but Fi themselves just told me I would be better off with 2 12's or a single 15 with those dimensions - given the fact I don't want to build inside of the trunk. Which is the same response I got in an older thread from a lot of the members. Would you mind going just a bit more in depth on your answer? I really appreciate it man.
ShadeTreeMechanic Posted November 26, 2016 Report Posted November 26, 2016 The bl looks like a real sub. This Fiday 15 has a tiny magnet and a svc 2 inch voice coil and looks like a promo item to me. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Miguels Posted November 26, 2016 Report Posted November 26, 2016 get the bl... you will be able to get recones if you ever need them.. the fiday sub you will have to replace my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
