Bought a NEWER Bimmer :D
I'll be in ge market for a new toy soon and I've always liked the e60 BMW. I hear that at around 100k miles they do require major mantainence, which scares me a bit. Congrats on your new toy brother.
Baron,
Here are some videos I am posting up on my You Tube channel.
Here I am diagnosing a common "No Heat" situation. When I purchased the car I did not test the heat. It was sunny and I was driving with the top down. My mistake. It dipped down to 58 degrees with the top down and that's when I found out I had no heat!!!!!!
First attempt: Thermostat. Didn't fix it!!
Next step "Heater Valve Test". It failed.
What a working heater valve should look and sound like. All 5,6,7 series have this sort of heater valve.
The electric thermostat was $78. The heater valve new at the dealership is around $300. $175 on line if you can find it. Me, I went to LKQ and found one off an X5 for $3.46!!!!! So for $81.46 I fixed 2 things that could have cost me around $600 at the dealership or $400 at an indy shop.
I still need to check the aux water pump that feeds the heater core at idle. I have heat when driving, but need to check at idle. I think mine works. Simple test. Brown is ground, and the other wire is the (+). These engines run at 500 rpm at idle, and it can't flow coolant to the heater core to offer heat. The aux pump fixes that. It's $95.00 new or $10.00 at LKQ. Do things like this and you too can own a Bimmer. If you can't....DON'T BUY A BIMMER! lol.
-Frank
im using full synthetic 5-20w .. my friend replaced the ccv with cheap ones.. i might have to get oem and see if that helps
yeah, I replaced mine on the white one was well. Keep in mind, if you see the BMW bulletins. Some of their motors DO CONSUME ABOUT 1 QT PER 1K MILES. They are not calling this excessive! lol. I'm at 1 Quart every 1 month. I need to figure out how much I drive in a month and do the math!.
-Frank
5w-20 is the wrong oil weight for that car,
BMW suggest 5w-30, if it was mine I'd go with a 5w-40 synthetic.
My 2011 335i is in the garage since the Valvetronic broke down at 86kmi. The eccentric shaft gear and the worm-gear valvetronic motor wore each other out. If you have the Bentley BMW manual and are competent with a wrench in hand, they arent too bad to work on, in general. The only problem is the diagnostics tool costs around $3k, which I refuse to buy. So each time I work on her, I have to either peg leg her to the shop or flatbed her there for a reflash. I still love the car, though. Drives like silk.
Congrats on the purchase Deez!
IG @walledsonic
Get the LOC harness from www.technicpnp.com no need to splice anything and you get the added benefit of a switched power with it. This is what I run in my car.
Thanks for the heads up!!!! I contacted him today. I should be getting a refund on my Camaro balance shaft. Around $70 so it will go towards that!
-Frank
Thanks!! Yeah, that's the thing. The 3 Series I can work all day long. So far I replaced the thermostat, the heater valve. Saved me a bunch. I rolled the savings into having the ac evac'ed and recharged at European Auto Haus here in Tampa for $171. Saved $20 since I'm a repeat costumer. :D In it for $255 so far. I would have been easily at $1k if I didn't do it myself. Going to have to get a car cover since she sits under my large oak right now until I can park her in the garage.
-Frank
  • 1 month later...
Update:
I found out the driver's side rear had 3 cracks on the inner lip edge.  Seems the Style 121 made by Gilardi for BMW had a class action law suit due to poorly made 19" upgraded rims yrs ago. The verdict forced BMW to pay back owners up to $500 per repaired rim with receipt.  This class action ended yrs ago so I'm S.O.L.  So my options were to buy another refurbished Style 121 rear from Ebay and take my chances or get after market rims. I chose the latter.
STR Racing 607 Titanium. Staggered set up.  19x8.5 et 15 fronts,  19x10 et 20. 245/40/19 front and 285/30/19 rears.  Great rear wheel clearance. I will probably go with 40 series when the rears wear down.  285/35/19 is what is on the M6.
Had to buy 2 new front tires.  Got a deal on 2 barely used Good Year Eagle RS-As. One had a slit on the side wall, so they're getting me one from the Clearwater Store.  Right now there's a China brand on her now.
Next project. Subs.
-Frank
Wow, those look great Frank.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1319 Guests (See full list)
