pitbullninja Posted December 22, 2016 Report Posted December 22, 2016 My question... can I run active with a kdc bt765hd? If not what should I do
bigmizzle99 Posted December 22, 2016 Report Posted December 22, 2016 Omg, are those Bratz dolls on that bed? Camaro SS Build Altima build 2.0 Altima build 1.0
pitbullninja Posted December 22, 2016 Author Report Posted December 22, 2016 It's actually a collectors item
pitbullninja Posted December 22, 2016 Author Report Posted December 22, 2016 Does anyone know about the head unit being able to run active????
ShadeTreeMechanic Posted December 22, 2016 Report Posted December 22, 2016 Is it a Kenwood? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bighossf150 Posted December 22, 2016 Report Posted December 22, 2016 ls swap? Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
pitbullninja Posted December 22, 2016 Author Report Posted December 22, 2016 2.3 in it while I put back together my 306 forged internals dunno the power tho
ShadeTreeMechanic Posted December 22, 2016 Report Posted December 22, 2016 Looks like it has built in high pass and low pass filters. So it should work. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
