MrSkippyJ Posted December 24, 2016 Report Posted December 24, 2016 The high pass for the mids could be set at 80hz on the amp and low pass for mids could be set at 4khz on the head unit. Or just high pass at 80hz and let them play all the way up on the top end. Ideally the mid to tweet crossover point should be a lot lower than 4khz but it depends on what the tweeter is capable of. I see what you're getting at. He could also bandpass the mids with a combination of headunit and amp crossover, if the ranges are wide enough on both. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
oldsoundguy Posted December 24, 2016 Report Posted December 24, 2016 The 6.5 pro audio were loud but not much mid bass. I think that with the super tweets might be a little much but its all subjective. As far as sound quality not much of that warm sounding music from those speakers. But if your looking for loud. Yes 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
pitbullninja Posted December 25, 2016 Author Report Posted December 25, 2016 Update ordered some 1"spacers for the doors because power window motor bracket in the way
pitbullninja Posted December 25, 2016 Author Report Posted December 25, 2016 Could some one send a pic of the gain side of their 90.4 running these for daily use no sub
reedal Posted December 25, 2016 Report Posted December 25, 2016 why do you need a pic of the gain side of the amp? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
SkarredSierra Posted December 25, 2016 Report Posted December 25, 2016 Use a dd1 or oscope to set gains properly.
pitbullninja Posted December 25, 2016 Author Report Posted December 25, 2016 Update wired not mounted very shrill tweeters gain on 5% tweets 30% mids alternator wine present now I sound supercharged... anyway you guys were right very very shrill and no mid bass I'm sad ...I bough the amp 3 blsck Fridays ago been waiting
pitbullninja Posted December 25, 2016 Author Report Posted December 25, 2016 why do you need a pic of the gain side of the amp?I was uncomfortable going stock to running active
oldsoundguy Posted December 25, 2016 Report Posted December 25, 2016 The amp is fine its just the PA and Super tweets. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
reedal Posted December 25, 2016 Report Posted December 25, 2016 I'm not sure how that would help you though. There are few people who run active using just the amp's crossovers. I have the 90x4, and I use the crossovers on my 80PRS for active because it's more precise. Even if someone did run the 90x4 active using it's crossovers, that doesn't mean the settings would be the same as yours (250hz on mine won't be 250hz on yours if the potentiometer is in the exact same position), nor would that be the ideal crossover points for your speakers. You can set the crossover points using a multimeter. I'd recommend 80hz HPF for the mids, but I can't tell you where for the tweets cause I don't use the super tweets. I cross my SQ'd PA mids at around 3 or 4khz I think and let my tweets do the rest, but I have their dome tweets. play the tone of the frequency you want the crossover set at (speakers disconnected to avoid damage). Place the positive and negative leads of your multimeter on the speaker outputs, with the multimeter set to measure AC voltage. For HPF, turn it all of the way counter clockwise. For LPF, turn it all of the way clockwise. Then, for whichever filter you are adjusting, slowly turn in the opposite direct of your initial setting, until the voltage on the multimeter begins to drop. repeat for each filter you wish to set. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
