I currently have two 12" JL Audio W0 in a JL Audio basswedge box and running off a Alpine 500watt amp at 2ohms. I have this exact setup below in the link. I wanna know if I switch from my current setup to 1 13 JL Audio W7 in a custom ported box and run it off the JL Audio HD1200/1 will I gain output and lose output? and will I have better or worse sound quality?
http://www.jlaudio.ca/cp212-w0v3-car-audio-basswedge-subwoofer-systems-93283
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
With the proper enclosure, yes, it will have more output. As far as sound quality goes, it really just comes down to what you listen to and what you want it to sound like.
I listen to regular rap music> I just need space in the trunk now. Would the JL Audio spec box work or should I go bigger?
Your losing cone area, so it might not be as great an improvement as you think.
Your going from 2 12's to one 13" on double the power, so it may be very close in output.
If you want to increase your output i would up to the 12w3 in a new enclosure on the 1200w amp you have or are getting.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I dont know what youre saying but I know I went from two 12" digital designs 2512 to a single fi audio SP4 15" and was amazed how much better the single fi audio 15 was
Boxes were about the same size and on same power
yet your cone area increased by a bit.  his will be going slightly down.
he is also looking 2 shrink his box size for more trunk room
good luck with any kind of louds with that goal
I think they would be about the same. I would take the two 12s and build a new box and put the 1200 on them. Then you would be doing something.
Pioneer 80PRS
Yeah the JL Audio W0 is 2 12 on a 500watt Alpine amp in a JL prefab box. The single 13 w7 would be in a custom ported box and would be running off the HD1200. If I lose output I might as well go with 2 12 Sundown SA or 2 12 JL Audio W6
Anyone else can chime in? A good single 15" that will take about 1500RMS and box size wont be too big?
