Could my volt meter drain my battery over night?
Put the volt meter on the remote wire on the amp
If you do that then you'll only be getting voltage from your remote wire, which would be a function of voltage drop through the wiring to the deck and across the remote wire itself
Might want to consult with the spec sheet for the deck before doing that, the remote wire is only rated to supply so much power
Brand new. And yea I was thinking it won't be anything to worry about but if it does I have an extra on and off switch I can wire to it
this is my first build, i have been waiting 4-5 years to have this done
95 chevy 2 door tahoe 5.7
Xs power d3400
Singer 275amp alternator
Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders
Sundown SAE-1500d
Mbquart onyx OA800.4
Stinger 4400 series RCAs and stinger volt meter
Fi Q NEO 18, 7.5 cubes tuned 32hz
Pioneer MVH-X690BS H/U
Kicker CSS 6.5 comp sets in front doors
Kicker KSC 4x10 coaxials in rear
GTMAT and FAT MAT deadner
Xenon 10k Blue HIDs
yea i went out this morniing and it showed 12.7 and when i shut the truck off it was 13.. i know it a good drain but as long as im not getting close to 12 its ok right??
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
  • Who's Online   1 Member, 0 Anonymous, 1709 Guests (See full list)
