How it going so I'm new to the smd family. But I've always loved car audio. I've never put sound deadener in a car before so was just looking to get some advice on the best sound deadener for your buck. I know second skin pro is one of the best out there. But how about the other name brands like dynamat xtreme? Or are they just over rated. Just would like to know what else is out there. Thanks
Incase anyone's wondering what I'm running
2000 suburban 1500 Lt
4 jl audio c5 650
4 jl audio c5 tweeters w/ crossovers
1 jl audio 12w6v3 /ported (of course)
JL audio slash 300/4 mids/highs
JL audio slash 500/1
sds is another brand ... but literally every car audio accessory company makes their own "version"...
4 jl audio c5 650
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
I normally just go with Second Skin since it's a company I trust. It's better to do it right the first time then having to redo it a 2nd + 3rd time:
Here's the crappy FatMat and Elemental Designs vse1:
Here's Second Skin Damp Pro:
Here's Second Skin Damp B-Stock Regular (I think):
Here's Second Skin Alpha Damp (Discontinued) that I got for free from them (Won from their Facebook contest). It has some minor flaws for my application but still intact in the trunk just fine!:
Heck, I even used Second Skin Damp Pro to seal off my subs from the trunk lol (not wised cause I had to rip if apart to take my sub box out. It works good for sealing off the subs from the trunk when you fire subs into the cabin though =_=
In conclusion, you won't regret Second Skin Audio Damp Pro.
Second skin is the best deadener I've used. I did use mostly Audio Technix deadener(discontinued) back when I did my suburban the first time. When I added some I got the bulk backs of NVX deadener on sonicelectronix. Sonic's stuff always gets to me in 2 days and it the deadener seemed to work well and was thick enough etc. to where I'd say it was good bang for your buck.
Since you haven't done deadener yet, make sure you have a wooden roller or something to install it properly so that it stays stuck to the surface.
97 Suburban
8 custom PSI Platform 3 18's
I'd also recommend getting a cheap pair of Kevlar Gloves on Amazon so you don't cut yourself :)
And a 100 pack of razor blades, second skin will dull a razor blade real quick.
Get lots of glass cleaner to so u can make sure any panels the ss will go on are clean and free of dirt or other grime.
this! any sound deader worth a dayum will have some decent foil you'll be cutting up
3 Steps to a Quiet Vehicle
Step 1 - Control Vibration and Resonance.
CLD Tiles™ applied to the roof.
CLD Tiles™ Applied to Roof of Dodge Ram Quad Cab
Step 2 - Block Sound with a Decoupled, Dense Barrier
Mass Loaded Vinyl (MLV) and Closed Cell Foam (CCF) on Floor of Pontiac Solstice
Mass Loaded Vinyl (MLV) and Closed Cell Foam (CCF) on Pontiac Solstice Floor
Step 3 - Absorb Middle to High Frequency Sound
Hydrophobic Melamine Foam inside wall of Mercedes Sprinter Cargo Van
Hydrophobic Melamine Foam (HMF) in Sprinter Cargo Van Wall
