Mike Shea Posted February 18, 2017 Report Share Posted February 18, 2017 Has anyone ever tried to install a DC to AC inverter into there build and use the produced AC power to supply an AGM or Lithium battery charger? Would the battery charger be able produce more of a charge to the system than the inverter would draw from the system resulting in a positive charge to the system over time? Link to comment Share on other sites More sharing options...
BassMunky Posted February 18, 2017 Report Share Posted February 18, 2017 Idk might be tooo strong. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 18, 2017 Report Share Posted February 18, 2017 That would be breaking physics. More output than input? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Skullz Posted February 18, 2017 Report Share Posted February 18, 2017 You would be putting extra on the alt to produce enough to power the inverter, so it may end up being a wash in the end. Just seems like a zero sum gain. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted February 18, 2017 Report Share Posted February 18, 2017 The inefficiency of each part of the system will always provide a net loss. People have been trying to get something for nothing for thousands of years. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Jessica Posted February 18, 2017 Report Share Posted February 18, 2017 two words. Wont Work Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
