06RTCharger Posted March 15, 2017 Report Share Posted March 15, 2017 Have you messed with the "input voltage" switch on the left side of the amp? Link to comment Share on other sites More sharing options...
cheatcode Posted March 15, 2017 Author Report Share Posted March 15, 2017 I'm speechless. I had it set to high this whole time and didn't realize it until now. Problem solved! Link to comment Share on other sites More sharing options...
MrSkippyJ Posted March 15, 2017 Report Share Posted March 15, 2017 aside from the fact that you are just arbitrarily turning your source down so you can for some reason turn the gains higher on your amp, have you considered that your amp just might be fucked up? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
cheatcode Posted March 15, 2017 Author Report Share Posted March 15, 2017 mrskippy, as i've said before, my amp is not the issue. what i'm doing isn't arbitrary at all, nobody who's running even a half decent setup is going to set their gains with their volume at 100% just because their hu doesn't clip there. you set it at 3/4 or maybe a little bit higher because if you set it at full volume and run an RTA and have to boost any frequencies at all you could potentially be clipping them and then you're left with absolutely 0 headroom. arbitrary is setting your volume at full blast to get more voltage when your volume is set to 100% because you think that's giving you some huge advantage. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted March 15, 2017 Report Share Posted March 15, 2017 alrighty then, good luck. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
cheatcode Posted March 15, 2017 Author Report Share Posted March 15, 2017 With people like you on this forum I'm going to need it. Link to comment Share on other sites More sharing options...
06RTCharger Posted March 15, 2017 Report Share Posted March 15, 2017 I thought u cut frequencies if anything? You dont boost. Cut peeks to match valleys. Not raise valleys to match peaks. Link to comment Share on other sites More sharing options...
06RTCharger Posted March 15, 2017 Report Share Posted March 15, 2017 To me the point of using a %100 clean max volume, is to match ur amps %100 clean max output. So when ur headunit is at %100 maxed out clean volume, ur amps is also at %100 maxed out clean output. Are you trying to get %100 max clean output from ur amp with ur headunit at 26 volume? Link to comment Share on other sites More sharing options...
cheatcode Posted March 15, 2017 Author Report Share Posted March 15, 2017 i'm done with this thread. i hope an admin comes and deletes the entire thing ..and for the record, in case you didn't catch my sarcasm, the input voltage wasn't the issue, i had it correctly set to "low". Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 15, 2017 Report Share Posted March 15, 2017 So it comes down to installer error. Link to comment Share on other sites More sharing options...
