Not sure where to post this DSP question
I have a question and I apologize if I posted this in the wrong section:
If you have your amps set so that the speakers do not distort at max headunit volume and you add a DSP to the chain before the amps, do you have to reset the amp gains, or should they be lower? I dont want to be too low in noise floor or too high, I like tuning so that at max volume none of my speakers will distort even on the most absurdly compressed modern dance songs.
I cant help with the question at hand. But i can tell you where you'd get more help. At the homepage, scroll down to the "Equipment" section. Then under the "Headunits, processors, Eq" topics, you can post ur question there. Dsp is a processor.
I agree with Duck. Any time I make a change I will go back and set the gain again. I like to run a high signal so I can keep the amp gains low. What kind of DSP is it?
Pioneer 80PRS
