YouWouldKnow Posted April 21, 2017 Report Posted April 21, 2017 I was thinking about mounting ring terminal anl fuse holders to my battery, I was going to put a sheet of abs plastic in between the battery and the fuses just in case and then mount the fuses on the plastic but I was curious if this would be safe and how should I mount the plastic to the battery and how should I mount the fuse holder to the plastic? should I use velcro? glue? caulk?
boomintahoe Posted April 21, 2017 Report Posted April 21, 2017 Hell no. On the firewall, side of 1/4 panel, someplace solid is the ideal choice. I've even seen them upside down mounted under a bracket in the engine compartment. Check out some youtube vid's for ideas.
YouWouldKnow Posted April 21, 2017 Author Report Posted April 21, 2017 3 hours ago, boomintahoe said: Hell no. On the firewall, side of 1/4 panel, someplace solid is the ideal choice. I've even seen them upside down mounted under a bracket in the engine compartment. Check out some youtube vid's for ideas. there's not much room, especially since now I have to fuse main cars power wire because I need to extend it to reach new battery post, why not mount it to the battery? anl fuses dont ussually melt, do they?
boomintahoe Posted April 21, 2017 Report Posted April 21, 2017 57 minutes ago, YouWouldKnow said: there's not much room, especially since now I have to fuse main cars power wire because I need to extend it to reach new battery post, why not mount it to the battery? anl fuses dont ussually melt, do they? Oh yes they can if connections aren't tight. Seen plenty of scary pics. Post a pic of your engine bay.
Kyblack76 Posted April 21, 2017 Report Posted April 21, 2017 If your melting a fuse, something else is wrong. And if it does melt, then they blow, like a fuse should. I dont get why its not safe to put a fuse on the bat terminal. Some one please fill me in why it is such a bad idea, as we have 3 dozen fuses, directly on both the battery terminal(s), and a buss bar. Both coming from the alt runs, and going to the amps. What should we be worried about????? Fill me in please. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
WalledSonic Posted April 21, 2017 Report Posted April 21, 2017 Not a big deal. I'd like to see the 'scary pics' though. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
MySetupIsntLoud Posted April 21, 2017 Report Posted April 21, 2017 If your fuse holder has like a little mounting square under it, you can drill into that onto the piece of plastic. When improperly secured they can move around and bump into things in your engine compartment. With the heat going through your fuse holder and the movement, it will crack and break over time...
WalledSonic Posted April 21, 2017 Report Posted April 21, 2017 3 minutes ago, MySetupIsntLoud said: If your fuse holder has like a little mounting square under it, you can drill into that onto the piece of plastic. When improperly secured they can move around and bump into things in your engine compartment. With the heat going through your fuse holder and the movement, it will crack and break over time... Not likely. Provide picture proof and then we can point out where someone went wrong. Notice half of the shit under your hood is plastic... Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Kyblack76 Posted April 21, 2017 Report Posted April 21, 2017 I mean,... Having something improperly installed, anything improperly installed, will cause issues, But, id think that really goes with out saying. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
