Sundown42089 Posted April 23, 2017 Report Share Posted April 23, 2017 Or does it matter Link to comment Share on other sites More sharing options...
audiofanaticz Posted April 23, 2017 Report Share Posted April 23, 2017 leave the oem wires. Link to comment Share on other sites More sharing options...
boomintahoe Posted April 23, 2017 Report Share Posted April 23, 2017 Shouldn't matter. Link to comment Share on other sites More sharing options...
Sundown42089 Posted April 23, 2017 Author Report Share Posted April 23, 2017 Thanks Link to comment Share on other sites More sharing options...
snafu Posted May 16, 2017 Report Share Posted May 16, 2017 Hmmm . . . If you install a fused charge lead as part of your upgrade and leave the stock charge lead in place, the fuse doesn't do you much good. If the upgraded charge lead is not fused, then all is OK. Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner! Link to comment Share on other sites More sharing options...
RedFred Posted May 25, 2017 Report Share Posted May 25, 2017 I always leave the OEM wires and assume electricity will naturally take the path of least resistance. The only reason to remove it is if you have a really cluttered wire mess in the engine bay. The benefit is that if any of your aftermarket runs come loose, maybe your OEM lines will be intact and you can continue as usual until you get time to fix it. Link to comment Share on other sites More sharing options...
