Polyfill
dsw422
Hey guys. I asked this question in my build log but No one has answered . I need to lower the tuning of my rear chamber (4th order) but am unable to increase volume. I will be using polyfill to hopefully get the desired effect.. only thing is, I don't know how much to add..
4th order wall build.
2 RE MT 18s , 6.25 sealed, 13.5 ported.
Thanks for any help..
P.s. I will be buying the polyfill that comes in the 10lb box at Wal-Mart..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
You can put up to around 1.25 - 1.5 lbs per cubic foot of polyfill in.  It will be packed in there pretty tight at that point though.
While putting polyfill in the rear chamber will lower your sealed resonance (sealed chambers don't have a "tuning"), it will also lower your efficiency.  Its probably going to cost you output.
Builds:
Here's a RE XXX 15" enclosure with specs rear: 2 net, front: 4 net @ 49Hz with 100 square inches of port area. Yellow: no damping in either chamber, Orange: "heavy" damping on the rear chamber, no damping on the front chamber:
From the figure you would get a very modest gain below tuning, around tuning a softer peak, this maybe worthwhile for daily setup but not for metering.
If I remember right MTs are recommended for a very large sealed box, and not recommended in a 4th BP simply because it would be too big to fit in most vehicles, if so, most likely your box would not be large enough.
try egg crate foam on the walls of the sealed section
it should lower the frequency well but it will also absorb sound waves on the sealed side...wait not sure if this is a good thing or bad since its sealed
joe whats your thoughts
https://www.amazon.com/Soundproofing-Acoustic-Eggcrate-Studio-Wedges/dp/B01EIHFOTM/ref=sr_1_7?s=musical-instruments&ie=UTF8&qid=1494688615&sr=1-7&keywords=acoustic+foam
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
I use egg crate to eliminate reverberation or the hollow sound in a box. I don't know if it would have same effect as a full box of poly fill. Maybe the same as a little bit of poly.
Edit: I use the cheap foam mattress pad kind.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1181 Guests (See full list)
