Check my build before I start?
dudeogo
I have decided on 2 FU Audio 750v2 18s on a CAB 1600.1 @1 ohm. They will be in a 12 net cubic feet box I designed tuned to 34 hz. Any suggestions on changes in equipment or box before I commit and order parts?
Stage 3 2008 Mazdaspeed 3
MIDS/HIGHS        BASS
8 Unlawful Sounds Mark VIIIs                                                  2 15s (in talks with a few companies)
8 Unlawful Sounds Super Tweeters                                       Soundigital EVO 5000
Amps: Something Brazilian
To do it the right way from the start, honestly I would choose a different amp. While a few people have had success with it, it seems to have a bad track record for reliability.
bdr electronics is a well known amp repair house that does warranty work for Sundown. They have great deals on refurbished Sundown amps that carry a full warranty.
http://www.db-r.com/sell/store3/index.php?main_page=product_info&cPath=1_45_97&products_id=171
Pioneer 80PRS
For that price, I'll buy that amp!
MIDS/HIGHS        BASS
If you post your box design we can look it over and make sure it will work well for you.
Builds:
They're all on paper sketches, I'm not very good with Google SketchUp. It is 12 cubes net with a 26 inch long slot port with a port area of 192 square inches. So 16 square inches per cube.
MIDS/HIGHS        BASS
Sounds good.  Those subs are going to roll off on the low end a bit higher that other subs would, I'd be tempted to tune a little lower, like 28 - 30 Hz.  You would lose a little output in the 40-50 Hz range, but you would gain some between 30-40 and would have smoother frequency response.  Just a suggestion.
Builds:
I'll shoot for 30 then. Thanks! I learned how to use SketchUp so if you would like to see design pics shoot me an email at [email protected]
MIDS/HIGHS        BASS
This one is 30 hz
MIDS/HIGHS        BASS
Those CAb amps will certainly do the job... Yes, I've had some issues " possibly caused by me"... but warrantied with no issues and I'm running them at 2 ohm each into EVL 12's in a small box tuned to 28 hz or so... it doesn't make water ripple in China like some systems do, but I'm happy for now... I'm sure I'll tear it all apart again eventually... LOL ! I'd recommend sizegdM.jpgthis amp to anyone who is tryin' to save a buck!... this was when I ran 3 12's @ 2.66 strapped... still have same amp rack...
This is the current setup... tuned to 28 or so... each amp loaded at 2 ohm...sounds good to me!
That bracing is pretty low and won't do what you're wanting it to do.
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
