Decaf Astra Question
Hey, so I've been studying the decaf astra for a while and I can't figure out for the life of me what's going on that makes the lows hit so hard... but I have a theory. I'm thinking it's a quasi 6th-order bandpass with the cabin acting as an 8th order chamber. If you look at the specs of the woofers, here, the resonant frequency of them free air is 40hz. Thiele and Small stated at least in ported boxes that they should be tuned at f(s) because that's where the sub operates most efficiently, but hurricane winds don't lie. I know resonant frequency isn't the only parameter that matters, but I'm trying to figure out how to do something similar so I'd like to understand how it works. I've tried getting in contact with the owner over YouTube comments, but there's an obvious language barrier and I'm sure he doesn't have time in the day to answer all the many comments he gets. Thanks in advance for your help!
- 2009 Toyota Matrix Base -
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
- SoundQubed SQ-2200.2 x 2 -
Contrary to popular belief, my opinion is that it's just a series tuned 6th, with the cabin and area above the rear 4 subs being the front, large chamber. The doors / windows act as the port when they are opened...think about it this way, if you built one big box with the same volume as his car's interior, then placed a box in it with 4 subs firing up, 2 firing forward, and port firing up, the larger chamber would act as one, even though 2 subs are firing forward.
I agree with that completely. So he's not just calculating the top portion as the chamber but also the cabin... So it's basically like sitting inside of the port. While a lesser box may do 140dB in the cabin, internal box sound pressure might reach 150dB or more. He's just taking advantage of that I suppose. But the inside doesn't look like it's that buff compared to the box. Just a stripper pole really, and you'd have to take every person and object in the car into consideration when determining the volume.
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
That also makes sense, but I can't get over why he's capable of getting those numbers on something like 17hz or even less with some pretty basic 1500 wRMS subs. I have 2 HDC3.118 D2s, so theoretically I could do something similar, right? I don't think I could expect a 160 at 15hz or anything, but I'd like to at least get 20hz - 40hz flat and have midbass take care of the rest.
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
That's true. 6 15's on 13000w (not sure if that power is still current) is nothing to sneeze at in any car. I was hoping by using thick materials for my box I could take up enough space that the cabin would act as 1/8th space or at least make it easier to pressurize.
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
I was thinking his box looked small for six 15s especially ported. What do you guys think?
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1101 Guests (See full list)
