Karkov Posted June 13, 2017 Report Posted June 13, 2017 On 6/11/2017 at 5:15 AM, reedal said: x2 X3 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
06RTCharger Posted June 13, 2017 Report Posted June 13, 2017 Is there any scenario in car audio where you would need an isolator???
ShadeTreeMechanic Posted June 13, 2017 Report Posted June 13, 2017 no 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
reedal Posted June 13, 2017 Report Posted June 13, 2017 27 minutes ago, 06RTCharger said: Is there any scenario in car audio where you would need an isolator??? An isolator is really only needed when you're sitting with the engine off and electronics still running, that way you don't drain your starting battery. It's mostly used for boats where they sit and fish or something and have music playing with the engine off. Unless you're trolling, most boat operators leave the engine off while fishing SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
06RTCharger Posted June 14, 2017 Report Posted June 14, 2017 Oh ok i get it. I was also thinking i might need one. But you can avoid needing it by not running ur stereo a lot while the engine is off? Makes sense, thanks.
