Electrical for 7.5k at .5 ohm
What do you guys recommend running for 7,500 watts at .5 ohm? It's an scv7500 on 2 z v.5 15" d2s. I currently have 2 Mechman 270s and a stock alt on a triple bracket with a D3400 up front and 4 D3100s in the back, but it still doesn't seem like it's enough. It goes into 11s even while driving. 02 Tahoe 5.3L
You may want to check the integrity of your components.  I have a SCV6000D wired down to 0.8ohm with a Singer 240A and (1) D3400 and (3) D3100s, and I dont dip below 12.0 at idle.  You should be fine with all the alternator power you have.
IG @walledsonic
Yeah, doesn't make much sense to me either. But I've looked everything over, charged up my batteries, etc. and it still isn't as solid as I'd hoped. I was banking on never dropping below 13s, but that didn't happen. Granted I don't drop to 11s all the time, but I do see it.
Load test your alts and check each battery's voltage independently.  Measure final impedance of the subs going into your amp to confirm you're actually at 0.5ohm and not lower.
IG @walledsonic
I'm running 16k rms (2 dd m5s) on a mechman 320 1 80 ah lithium and 2 group 31 agms and hardly get under 13 unless idling
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
OP, that does seem low.  Check amperage alts are making and load test all batts as already stated.  maybe you're at lower ohmload?  6 phase alts or no?  Does your vehicle hot charge low like in the 13's?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
You might have a bad connection somewhere or a battery might be going bad.
Pioneer 80PRS
I definitely thought something was strange too. I figured my electrical would be solid enough. But everything is fine. I tested everything. The alternators are all less than a year old and all the D3100s are just a few months old. I don't know what it could be. I know my amp pulls like 800 amps, so I thought maybe I needed more alternator power, but I see plenty of guys out there running more with less. I don't know.. It's very annoying.
How many runs do you have front to back? Are you grounded to the frame for both the front and rear batteries? Big 3 I assume? Maybe if you could post a few pictures of your wiring it would help us understand what you have.
Pioneer 80PRS
I have 4 runs + and - of 1/0 sky high ofc. Big 3 done. Front and rear batteries are both grounded directly to the frame. Stock alternator is in stock location with stock wiring. The 2 Mechman 270s both have 1/0 on + and - . I'll try and post some pictures here in a few.
  • Who's Online   0 Members, 0 Anonymous, 2095 Guests (See full list)
