Spanka Posted June 27, 2017 Author Report Posted June 27, 2017 but don't you lose volume control if you tap before the amp?
reedal Posted June 27, 2017 Report Posted June 27, 2017 No SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Spanka Posted June 27, 2017 Author Report Posted June 27, 2017 No? doesn't the factory amp/DSP control everything including fade, volume and eq settings?
WalledSonic Posted June 27, 2017 Report Posted June 27, 2017 My assumption (currently) is that the head unit controls basic functions like volume, fade, etc. and that the DSP controls crossovers. Not 100% sure, man. Thats why you have to test ? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Spanka Posted June 27, 2017 Author Report Posted June 27, 2017 HAHA well I will let yall know tonight!
slowfkncar Posted June 27, 2017 Report Posted June 27, 2017 Actually the infinity/alpine systems have the volume & fader built into the amp, he is right. The volume control and fader is handled via can-bus (orange white/white wires in harness) and the pre-amp outputs are full range fixed. Also, the factory woofer is bp'ed somewhere like 35hz-80hz/24db which is why you might not have that much output below 30hz. Every output at the factory amp is either bp'ed or hpf & summing these together with an OEM audio integration box will help greatly when tuned correctly. The factory woofer signal is usually a pita with low tuned enclosure because you end up needing to boost it below 30hz which again, requires an integration box.
WalledSonic Posted June 27, 2017 Report Posted June 27, 2017 @slowfkncar, here are two pics we took when we removed my buddy's jeep head unit: Back of the head unit: The plug going INTO the DSP from the head unit: So grabbing signal at the preamp wires wont help since volume control is handled via the orangewhite/white wires? Also, have you used an OEM integration box for these style vehicles? We looked around for one a month or so ago and couldnt find what we were looking for, but maybe I was looking for the wrong thing. Great input, thanks man. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
WalledSonic Posted June 27, 2017 Report Posted June 27, 2017 Although you mentioned the signal is bandpassed, Spanka showed some measured voltage values that show it is undergoing a frequency cutoff around 74Hz and continuously sloping off. Im curious about that. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
slowfkncar Posted June 27, 2017 Report Posted June 27, 2017 10 minutes ago, WalledSonic said: Although you mentioned the signal is bandpassed, Spanka showed some measured voltage values that show it is undergoing a frequency cutoff around 74Hz and continuously sloping off. Im curious about that. Okay i remember testing it once before, i might be a little off but it was something along the lines of Woofer 35-80hz / front doors 80-500hz / front dash 500hz^ / rear doors 35hz^ Also, forgive me when i speak of OEM integration i was referring to using an RF360.3 or any compatible multi-channel summing device with some ability to EQ his factory signals. Yes I've used them on amplified chryslers with pretty good results but nothing beats a new head unit lol. Look at the stereo harness, it's got power,ground,left spk,right spk and everything els is handled through the white-white/org (ignition,dimmer,amplifier,fader ect) I have tried using the pac c2a-chy5 also but it still had fixed volume control. On a side note, the RF360.3 has its own volume control built into its control center knobs and can be used as volume if tapping the factory stereo pre-amp. It also has multiple inputs and can be selected with the knobs right at the control center.
WalledSonic Posted June 27, 2017 Report Posted June 27, 2017 Damn, thats a bummer. But im glad you've already done a lot of the footwork. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
