I have a R.F. P600.2. For the longest time it was working just fine. Then one day it just stopped. I finally nailed the issue down to the Power Block (Power, Ground, Rem) area. If i lift up on my wires just a little bit the amp turns on with no problem. But it only lasts for a few seconds. I think that i have to re-solder the connections internally. but im not sure...any ideas?
Pic isnt displaying.  Google gave me a 403 error.
IG @walledsonic
Sorry about the pic not displaying....took it with my phone and sent to email then posted. Im trying to check that now.
i didnt find the issue that you stated...maybe i was looking in the wrong place
It does kinda sound like a loose input terminal on the board, open it up and check? Some of the older chrome plated RF amps had thin boards, atleast the lower models did.
1 hour ago, Trogdor said:
Thanks. I will check that....is there a way to reinforce the terminal inputs?
No, not that i know of.
you can just clean the area with denatured alcohol before & after, i use 60/40 2mm rosin core solder on all my big connections.
