Is 4gauge good enough to run 2 amps
So here is my question, I have ofc 4 gauge ran from the front to my back battery. Right now I only have 1 -1000 watt mono block for my sub. I want to power my door speakers with a 4 channel amp. Should I run 0 gauge to a distro block and continue 0 to my power cell and use the 4 gauge for my door speaker amp. Or should I just do another run of 4 gauge to my second amp.
08 f-150 foose edition
Roush supercharger
22'' foose chrome rims
Carriage Works brushed billet grill
Elite tonneau cover
ZeeZ underbody led multi color glow kit
Black horse racing electric exhaust cutout
Crown suspension rear lowering shackles
Eibach coil springs and leaf springs
Pioneer DEH-x3800s cd player
 audiopipe  200 watt crossovers
4 mclaren 5x7 250 watts speakers
4 soundstream 150 watt dome tweeters
Audiopipe Apcl-1000 mono amp
1-Sundown audio 15"sa
Box built by concept enclosures tuned to 35 hz with spare 32hz aero ports
1-xs power 950 battery
All skyhigh audio,power,ground,RCA,speaker, remote turn on
home set-up Onkyo receiver tx-DS676 5.1 575 watts KLH 5 disc cd player Optonica 220 watt amp optimus 10-band EQ 2-floor standing technics speakers-10in w/mids 1-10in polk audio psw100 powered subwoofer 2-bowers & wilkins dm-17 bookshelf speakers
Depending on the fuse ratings of the 2 combined amps you could use 4 gauge. I use ofc 4 gauge for 2 amps. The combined fuses of both amps are only 130 amps at most. Im sure i only pull around 90 to 100.
The combined amps is 120
Roush supercharger
Elite tonneau cover
Ok thanks buddy
Roush supercharger
Elite tonneau cover
if you ever plan on upgrading i would run a 0 guage now. 4 guage is normally only rated at 150 amps and thats over sized wire like knukoncepts.. if your wire is cca then you need to upgrade your wire
Yes it's skyhigh ofc, my plan is to put in a distro block before my rear battery and branch off to the door speaker amp. If anyone has a better idea I'm all ears, thanks
Roush supercharger
Elite tonneau cover
That seems rather pointless imo when you can just attach a second 4awg cable for the other amp directly to the battery.
Realistically you can put  as many ring terminals with wires connected to the battery that you can fit as long as your able to screw the allen bolt down tightly... Or just buy battery blocks to bolt onto the battery then connect the wires to that.
  • Who's Online   0 Members, 0 Anonymous, 1578 Guests (See full list)
