bigmacjack Posted November 14, 2017 Report Posted November 14, 2017 So I have two subzeros both needed a recone; we had both the kits sitting at my work so I did one and fucked it up because of inexperience. But after a little practice I got the second one to work and it was dual 1 ohm. so I emailed Earthquake and they no longer make or have dual 1 ohm voice coils. so my question is can I run a Dual 1 ohm sub in series @ 2 and a dual 4 ohm sub in parallel @ 2, then parallel both together to get 1 ohm? and can i use these subs in the same box?
Jonathan Mills Posted November 14, 2017 Report Posted November 14, 2017 I would say yes as long as your getting the total resistance of 1 ohm at the amp so you have no issues there and yes you could use them in the same box.
ckeeler11 Posted November 14, 2017 Report Posted November 14, 2017 With different T/S Parameters it could cause problems, I would not put them in the same box.
WalledSonic Posted November 14, 2017 Report Posted November 14, 2017 10 hours ago, bigmacjack said: So I have two subzeros both needed a recone; we had both the kits sitting at my work so I did one and fucked it up because of inexperience. But after a little practice I got the second one to work and it was dual 1 ohm. so I emailed Earthquake and they no longer make or have dual 1 ohm voice coils. so my question is can I run a Dual 1 ohm sub in series @ 2 and a dual 4 ohm sub in parallel @ 2, then parallel both together to get 1 ohm? and can i use these subs in the same box? Hey man, since you already have the experience, why not just buy two new recones and redo them both? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Jonathan Mills Posted November 14, 2017 Report Posted November 14, 2017 20 minutes ago, WalledSonic said: If you are gonna have to recone both which might end up happening might wanna just try them out see what happens just as long as you keep the one ohm load to run your amp safely.
WalledSonic Posted November 14, 2017 Report Posted November 14, 2017 Just now, Jonathan Mills said: If you are gonna have to recone both which might end up happening might wanna just try them out see what happens just as long as you keep the one ohm load to run your amp safely. Different subs will act differently in the same enclosure. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bigmacjack Posted November 15, 2017 Author Report Posted November 15, 2017 23 hours ago, WalledSonic said: Hey man, since you already have the experience, why not just buy two new recones and redo them both? well because im on a very tight budget. 22 hours ago, WalledSonic said: Different subs will act differently in the same enclosure. i was planning on building the box with the port running down the center so i dont know if this would be considered separate chambers with a shared port?
WalledSonic Posted November 15, 2017 Report Posted November 15, 2017 Give it a shot man. It may work out well enough for what you're doing. However, think of it like this: If you put one type of shock/spring on your front driver's wheel, and then a different type of shock/spring on your front passenger wheel, do you think the car will handle evenly like stock? No. Will you make it to work in the morning? Probably, but you may not have optimum handling along the way. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bigmacjack Posted November 15, 2017 Author Report Posted November 15, 2017 2 minutes ago, WalledSonic said: Give it a shot man. It may work out well enough for what you're doing. However, think of it like this: If you put one type of shock/spring on your front driver's wheel, and then a different type of shock/spring on your front passenger wheel, do you think the car will handle evenly like stock? No. Will you make it to work in the morning? Probably, but you may not have optimum handling along the way. yea i realize what im doing. im just way to excited about these subs to wait any longer haha i've been staring at these things for 3 years now. its not like im gonna be trying to get numbers from them its just gonna be a daily driver. But i do have about 6 motors from these guys so later down the road i wanna buy 4 15" baskets and soft parts and put them in my Hatchback.
ckeeler11 Posted November 15, 2017 Report Posted November 15, 2017 5 hours ago, bigmacjack said: i was planning on building the box with the port running down the center so i dont know if this would be considered separate chambers with a shared port? That is one box. You would need to have a divider down the middle of the port for it to be 2 separate chambers. Why not just run the one until you can afford to recone both.
