i got this bad boy just sitting in its box along with another kicker 1/0 amp kit, a deka intimidator batt. for the system and have a 300 amp alt on the way. now the big question is what would a good amp be for it? i have plans for a second BTL (dual 2ohm) in the future im looking at about 3000 watts rms at 4 ohms/ 6000 watts at 1 ohm for around $1200. or am i asking a little too much?
Are you planning to run it at 2ohm or .5ohm?
Edited by slim8605
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
or would it be better to just get 2 amps?
2.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
preorder a sundown 5k
if you want to run em at .5 ohms, that's your best bet. those amps can be run at .5 ohms daily with no modification. just have a good electrical, which looks like you have under control, maybe a few more batts. otherwise you're gonna need 2 amps that are between 2-4k watts RMS @ 1 ohm (depending on the options you got...which i'm sure is fully loaded)
