WalledSonic Posted December 28, 2017 Report Posted December 28, 2017 Ive tried changing DMM leads, i made sure all connections are bare metal, etc etc. Ive found that how you orient your +/- leads on the DMM can change your measured continuity. Ive checked grounds all over the electrical system, with varied results. If i place the + DMM lead on the battery - and the - DMM lead on some grounded location, i get full continuity. If i place the - DMM lead on the battery - and the + DMM lead on some grounded location, i get a variety of values, usually 1.2 to 3.7 ohms, depending on location. WHYYYY??? Please, only reply if you have a logical response. Thank you. Maybe the fact i have the battery grounds still attached to the batteries is a problem. Going to test the same ground cables with no batteries attached this weekend to see what if i can repeat these measurements. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
WalledSonic Posted December 29, 2017 Author Report Posted December 29, 2017 @snafu , have you seen this before? Boggles my mind, makes no sense to me. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ShadeTreeMechanic Posted December 29, 2017 Report Posted December 29, 2017 I would suspect that there is a small amount of voltage that is throwing the reading off. I would expect to see 0.1 like the leads are connected together. Instead its either flat zero one way and greater than zero the other way. Try measuring millivolts at the same location to see if there is any voltage present. ps. I assume that the battery in your meter is good. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
WalledSonic Posted December 29, 2017 Author Report Posted December 29, 2017 Little update, disconnected the grounds from the battery terminals and have now confirmed my ground run for the rear bank is good. I guess the battery does influence the DMM reading. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ShadeTreeMechanic Posted December 30, 2017 Report Posted December 30, 2017 Glad I could help. Are you checking connections because a problem developed or just verifying everything is good? Your Lithium is looking good in the back there too. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
snafu Posted January 2, 2018 Report Posted January 2, 2018 Hmmmm . . . no, I have not seen that before. However, I'm not sure exactly what you're testing here. You say the "grounds are good." In what respect? One cannot use a DMM to measure continuity from one ground point to another in an effort to determine a "good ground." It doesn't work that way - especially not with high powered car audio systems. Rather, one has to use the DMM to measure the difference in voltage between the ground of the accessory in question and the ground of the charging system (case of the alternator) with the system playing music at it's maximum volume. This measured voltage between these two points is referred to as voltage drop and in and of itself somewhat meaningless. However, the formula works as follows: Voltage Drop / Running Voltage = %age of Voltage Drop That %age must be less than 3% in order for the ground to be classified as "good." Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner!
WalledSonic Posted January 2, 2018 Author Report Posted January 2, 2018 I guess power under load versus with a DMM signal are two different things, along with how impedance of a woofer may change when measuring with just the IM-SG versus with the AMM-1 (under load). I saw your video recently testing voltage drop. I will try that out soon. Thank you for chiming in. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
snafu Posted January 2, 2018 Report Posted January 2, 2018 You're welcome Mr. SOTM Winner! Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner!
