BMS Posted January 16, 2018 Report Posted January 16, 2018 I need a new amp for daily use. My 12's are rated 2000 wrms (conservatively) and i have six so 12k. My ohm load is .75. ive been eyeballing the banda viking 1500.
Mitchaford Posted January 16, 2018 Report Posted January 16, 2018 Sundown NS-2 Crescendo 10k B2 M15R AA TFE IA.80.1 DC 10k Taramps Bass 12k or that banda you listed. You could also do two 6k amps. Little bit more selection if you went that route. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
ChevyBoy95 Posted January 16, 2018 Report Posted January 16, 2018 ^^ about covers it. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
BMS Posted January 16, 2018 Author Report Posted January 16, 2018 So no objections to the Banda though don't get me wrong amps like the encore 12k and b2 the Raven look very appealing but they cost twice as much and aren't as powerful. But yeah other than the amps you listed the emf audio merika is about the only other on the market I can think of other than huge amps such as the doomsday. And those other class d full bridge like stetsom and soundigital don't appeal to me as much as the Banda.
ChevyBoy95 Posted January 16, 2018 Report Posted January 16, 2018 31 minutes ago, BMS said: So no objections to the Banda though don't get me wrong amps like the encore 12k and b2 the Raven look very appealing but they cost twice as much and aren't as powerful. But yeah other than the amps you listed the emf audio merika is about the only other on the market I can think of other than huge amps such as the doomsday. And those other class d full bridge like stetsom and soundigital don't appeal to me as much as the Banda. Don't let wattage ratings fool you. Those amps are more expensive because the quality of components inside, the reliability, the durability, etc. I run taramps and love them, but they are cheap for a reason. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
BMS Posted January 16, 2018 Author Report Posted January 16, 2018 Will it last 2 years likely if so I'm good. My CT sounds lasted 2 days so.
BMS Posted January 16, 2018 Author Report Posted January 16, 2018 However I thought they were cheaper because they used less components in their design not cheaper ones necessarily.
WalledSonic Posted January 16, 2018 Report Posted January 16, 2018 Keep in mind long boards (over 5K usually) are more expensive to repair and some shops wont even take on the responsibility. Something for you to think about/consider when determining cost of ownership. I was going to do a AA TFHE at 0.7ohm but instead went with (2) AA 5Ks at 0.35ohm. No regrets. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ChevyBoy95 Posted January 16, 2018 Report Posted January 16, 2018 9 hours ago, BMS said: However I thought they were cheaper because they used less components in their design not cheaper ones necessarily. True in a sense, but the components ARE better quality in most of those korean big amps. Brazilians in general are more susceptible to vibration, low impedance, and whatnot. I personally have ran taramps and never had an issue (*1 issue but might have been my fault). 6 hours ago, WalledSonic said: Keep in mind long boards (over 5K usually) are more expensive to repair and some shops wont even take on the responsibility. Something for you to think about/consider when determining cost of ownership. I was going to do a AA TFHE at 0.7ohm but instead went with (2) AA 5Ks at 0.35ohm. No regrets. That is one perk to brazilian, less to fix IF something goes wrong. Generally a cheaper repair for same cause of death. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
SoCaLBaMF Posted January 17, 2018 Report Posted January 17, 2018 Personally love my Taramps hd10000s, never had an issue yet. Seem to be easier on my electrical as well. 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
