Box design help please....
Wishuponasub
Alright so I'm finally getting around to installing my gear I have accumulated and need to start planning for box and amp placement. I will be running 4 FI X 10s on an Ampere Audio 3800.1 at 1 ohm. I hate just saying design this for me but I really am clueless here and would appreciate the help.
Features X10
DUAL 2 | DUAL 4
Fs: 32.5 Hz | 32.5 Hz
Re: 1.4 Ohms/coil | 2.8 Ohms/coil
Qms: 6.01 | 6.01
Qes: .48 | .48
Qts: .44 | .44
Mms: 162g | 162g
Cms: 0.00mm/N | 0.00mm/N
Sd: 310cm^2 | 310cm^2
Vas: 19.66 l | 19.66 l
Spl: 83.3dB 1W/1m | 83.3dB 1W/1m
Bl: 14.01 N/A | 19.81 N/A
Xmax: 20mm
Rms: 750W
Sealed box: .2-.4 cuft
Ported box: .6-1.2 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.000”
Displacement: 0.07cuft
X Series: 10”, 12”, and 15″
Dual 2 and Dual 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional BP Cooling
Sorry for the light text.
The dimensions I came up with are 19"heigth, 37"width, 26" depth. That is the entire cargo area up to the seatline. That is all the way against the hatch too not leaving room for the port. So that would have to be taken into account. I would love for it to be 19"tall so I could look back and see them but it's not a must. Thank you advance for any help I receive.
edit: I have the D2 if that makes much of a difference.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
I guess I left a few details out.
I would definitely prefer ported. I mostly listen to rock/metal but when I really wanna get my bass fix I listen to rap. This setup will get metered but it's not to compete with. I just want a musical daily pounder.
Edit:
Damn so many details lol. It's going in a dodge caliber so subs up port back unless for some reason you think there is a better orientation.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
Post the design details back here before building, if you dont mind.  Some of the pros might happen to be online by then and can help with confirmation of the critical values.
IG @walledsonic
  • 1 month later...
Bump for interest/info
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1808 Guests (See full list)
