New Box Idea (Series 6th Order)
ChevyBoy95
Probably going to be rebuilding to a series 6th. Issue is, no real T/S on my current subs (B2 XM v1 15 d0.5's)
For those who have experience with series 6ths or know a thing or two, feel free to chime in.
REAR - 13.6 @ 28Hz (138sq in of port)
FRONT - 18.98 @ 58Hz (511sq in of port)
Power is 2 12k's (not ran full tilt though, too much power, assume 4kw per sub) and they have like 60-70mm p2p excursion. Goal is to play down to 25 with authority and annihilate low 30's and play up to about 45-50
I want the baffle flat (loading 90+ lb woofers in a flat wall SUCKS). I can also get more volume, but would like the keep the width and length to 49 for the sake of MDF comes as 49 width pieces (makes making it easy)
I have an IMSG you can borrow.  Then you can have the full set of TS Parameters for your subs :)
IG @walledsonic
can they be in the box when i use it? LOL, dey heavy
Haha no, you connect the tool to a free air sub and go through a process of following steps and entering the readout into D'Amore's spreadsheet.  By the end of it, you have every parameter.
So whenever you get around to removing the subs from the current wall, you can dial the design in and fine-tune your final design with the TS specs.  Open offer, should you choose to accept it.
IG @walledsonic
Ill keep it on my mind. I might get a wild hair and pull a sub, it aint super difficult, just not "fun".
  • Who's Online   0 Members, 0 Anonymous, 1055 Guests (See full list)
