mobilehomeguy Posted April 8, 2018 Report Posted April 8, 2018 I have a CT sounds 10 with dual 2 ohm voice coils.i checked the coils with my meter and they both check out for continuity and both read 1.8 ohms.when I hook the sub up to my amp,I get no output at all.need suggestions
CstrokerV Posted April 8, 2018 Report Posted April 8, 2018 Bad amp? Sub level output off on deck? my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Kyblack76 Posted April 8, 2018 Report Posted April 8, 2018 Keep using that meter. Play some music or a tone, and see if you have voltage coming out of the board. If you do, check things like (if the amplifier has one) the slave/master switch. Obviously, select master. But, use that meter you have, and see if you have output, and go from there SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
mobilehomeguy Posted April 8, 2018 Author Report Posted April 8, 2018 My amp is good as new.its pushing an AB xfl 15 as we speak
mobilehomeguy Posted April 8, 2018 Author Report Posted April 8, 2018 It's actually pushing an xfl 12 also.and banging the *@#$ out of them I might add.
shizzzon Posted April 8, 2018 Report Posted April 8, 2018 measure the resistance of each coil at the terminals of the sub with it disconnected from the amp and not connected to each terminal.
SkarredSierra Posted April 8, 2018 Report Posted April 8, 2018 U check the wires your using to connect it? Could be an issue there.
mobilehomeguy Posted April 9, 2018 Author Report Posted April 9, 2018 I am using same wires that run to my 15
