why are my subs showing 1.5ohms on volt meter when wired to 1ohm>?
why are my subs showing 1.5ohms on volt meter when wired to 1ohm>?  some of the wire i used to wire the subs is 10gauge and theres 1 jumper wire thats like 14gauge could that be why?
ORION HCCA 10.4 2000 watts RMS 4000 watts max
hifonics brutus 2600 bxi
Alpine IDA -305 Digital receiver
0 gauge power wire 250 amp fuse
800 watt BUTTKICKER BASS SHAKER
Kicker zx-400 amp to power buttkicker
When you set your meter to measure resistance, and only touch the meter’s leads together, what number do you get?
that's roughly within the voice coil tolerance especially if it's 2 or more subs. that's just DC resistance of the sub not what the amp actually sees when playing music.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
This^  start by doing this, then subtract your number
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
The setup is 2 soundqubbed hds2 15s.  Dvc 4ohms. I'll touch the leads together and subtract. So was I doing it wrong if I had the music turned off and just touched the leads to the speaker output terminals on my amp. It starts at like 1.8ohms the creeps down to 1.5 1.6. I figured this is why I'm not getting as many watts as I want out of my amp cause it's 1.5ohms
I measure mine not connected to anything but it may not matter, hopefully someone smarter than me shows up.  I am assuming you already triple checked your wiring to make sure you are wired to 1 ohm nominal to the amp? I don't know what DCR those subs come at.  Curious what resistance number you get touching your leads together.  What meter are you using?
I am just not able to think at the moment, so tired, lol, sorry......
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Ill check shortly it's just a cheap multimeter I got from parts express
  • 3 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 1727 Guests (See full list)
