Design help for F150 2018 supercrew Dual 12 under seat
Id like a down firing ported enclosure if anyone can help me id appreciate it, Possibly having the port external some how to save on internal displacement if possible .
Im lifting the seat so dimensions are
Depth 13
Front height 11.5
Rear height 8.5
Width - 54
since down firing please counter sink as well and if at all possible 2  plexiglass  windows ? optional im pushing it lol
2 x 12 in RE audio SEX first gen. Reconed with PSI parts dual 1ohm
Powered by a hifonics BRZ2000.1D
I need a simple sketchup diagram with dimensions I should be able to figure out all the cuts and parts  just let me know the angles used.
Recommended Enclosure Type
Ported / Vented
Sealed
Minimum Sealed Box Volume
0.75 cubic feet
Optimum Sealed Box Volume
Maximum Sealed Box Volume
1.0 cubic feet
Minimum Ported Box Volume
1.5 cubic feet
Optimum Ported Box Volume
Maximum Ported Box Volume
2.0 cubic feet
Top-Mount Depth
7"
Cutout Diameter
11-1/4"
Shallow Mount Installation
No
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
You are going to be a little on the small side to run ported. You have 3.5 cu ft. to work with and that does not account for the space you need for the subs excursion on the bottom., so probably closer to 3.0 cu ft. You want to be around 4-4.25 most likely.
54 minutes ago, shredder2 said:
Pair of 10's is pushing it in that space ported imo... here is one for 2-Sa 10's in that approximate space you've got... 2 12's ported looks like a bit of a stretch.
did you design that bad boy?
Yes... I'm a lurker on this forum mostly... but HAD to add my .02 regarding 2-12's underseat ported in this instance.
I felt an illustration would be best to make my point.
Sealed maybe... ported in space listed... imo, no.
Winisd/ Torres/ Sketchup... yes, it's my design.
its very nice!
I had a design done for me for 3 x SD3 -10s sealed but the subs are costing me 1000 dollars when I already own these two 12s, and the lift kit was $163.  I would like ported but sealed is not a deal breaker if I can use my existing 12s. or perhaps 1 x 12 ported.
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
Hey Shredder 2 what size and length port in that box u designed
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
IIRC its 5.9" ID 24" long or so... don't quote me as the drawings are on my computer, not Chromebook... it's been several months since I did the design so it's just a WAG atm... sorry
It's around 11in2^ft3 I think
  • Who's Online   0 Members, 0 Anonymous, 6509 Guests (See full list)
