system issues scratching my head at what happened
It could come down to a bad RCA, or that Cock Box too if the output voltage from RCAs is low. If this is the case, you should check the HU next to make sure that isn't the source of the issue. If it is not the issue, plug the RCAs from the HU to the sub amp directly, and jumper from that sub amp to the other with another set of RCAs, and test again.
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Replaced rca to bass knob with different rcas still same thing. What should the voltage read in rcas.
Checked it and I believe read around 2 volts. Leaning towards rca output on 80 prs somehow got weaker.
Going to write down all settings and reset hu to see if that works. If not going to try retry gainmatching dc5ks again before dropping $200+ on a hu
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Bypass the cockbox and see if anything changes.
Trouble shooting is a process of elimination, remove as much as possible to start and keep adding until you find the issue.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
What tone were you using when taking that reading? Should be around 40hz for testing sub out, and it should read around 6 volts for that deck. Read straight from the back of the deck to rule it out.
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
PRS wont output more than 5V max
IG @walledsonic
Ah, was going off of deck specs I found online, must've been for wrong deck. I see now on Crutchfield it is listing 5V. My bad!
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
  • 5 weeks later...
On 6/21/2018 at 11:24 AM, AlpineNut said:
Do you have a 2ndary battery or extra ones?  I had my 2ndary battery causing my amps to go into protect and once that was removed my amps turned on without a problem.
If so try removing them from the lines and see what happens.  Like just remove the positive wires, make sure to protect them and see what happens.
Now that's the issue I'm having with my system now.My system plays fine with just the front battery but once i added one in the trunk my amps go into protect mode also.Did you ever solve this problem
