Joshdashef Posted October 23, 2018 Report Posted October 23, 2018 Currently I have two XS power batteries; D5100R under the hood and a D3400 in the trunk. If I am playing music with the car off, what is the lowest voltage I can reach before causing damage to the batteries? I have a little stinger volt meter and analog one to watch it when the cars off. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Kyblack76 Posted October 23, 2018 Report Posted October 23, 2018 Your amp will shut off first SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
BassMunky Posted February 5, 2019 Report Posted February 5, 2019 10.8? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
SnowDrifter Posted February 5, 2019 Report Posted February 5, 2019 Realistically around 11.7-8v without load if you still want to be able to start your car. Accounting for key on draw, I'd avoid going below 11.4 range. Don't forget to charge your batteries at home doing this. The alternator won't fully juice the things up after a deep discharge ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
BassMunky Posted February 5, 2019 Report Posted February 5, 2019 Even if it only short time cause low bass notes? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
