TezasBassBox Posted December 1, 2018 Report Posted December 1, 2018 Setup is kicker zx750... Will add an extra 4 channel amp 50x4, line driver, likely swap stock batt for an xs agm, then prob get a small car for the amps. What alternator and batteries should I get for this setup. I'll do the big 3 as well. Thanks. Subs don't hit when powered by cheap amps!
ToNasty Posted December 1, 2018 Report Posted December 1, 2018 Stock alt is fine. Just upgrade the battery. I have a 16. Same as your 14 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
DTS909 Posted December 1, 2018 Report Posted December 1, 2018 Agm and big 3 Done VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
TezasBassBox Posted December 1, 2018 Author Report Posted December 1, 2018 Thanks guys. Currently the interstate battery and stock alternator leave the headlights dimming pretty badly. Figured I'd ask. Been into amps and subs for years but this new vehicle/ tech is a bit confusing. Subs don't hit when powered by cheap amps!
ToNasty Posted December 1, 2018 Report Posted December 1, 2018 Grab an xs4800. Upgrade the main ground and alt wire. And see how that goes. Should be plenty ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Broke_Audio_Addict Posted December 1, 2018 Report Posted December 1, 2018 The headlights will still dim even with a better alt. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
bmwking Posted December 1, 2018 Report Posted December 1, 2018 14 hours ago, TezasBassBox said: Thanks guys. Currently the interstate battery and stock alternator leave the headlights dimming pretty badly. Figured I'd ask. Been into amps and subs for years but this new vehicle/ tech is a bit confusing. want your headlights to stop dimming? go led. https://www.amazon.com/OPT7-Headlight-Bulbs-Clear-Arc-Beam/dp/B00VNBDWPK/ref=sr_1_1?ie=UTF8&qid=1458508907&sr=8-1&keywords=OPT7+H11 probably time for an upgrade on the old yellow lights anyway
TezasBassBox Posted December 2, 2018 Author Report Posted December 2, 2018 On 11/30/2018 at 9:28 PM, ToNasty said: Grab an xs4800. Upgrade the main ground and alt wire. And see how that goes. Should be plenty Right on. I'll put those on at the first of the list. 16 hours ago, Broke_Audio_Addict said: The headlights will still dim even with a better alt. This^^^ is what I don't get. With my older vehicles swapping the alternator and battery/ies cured this prob. Why not now? 10 hours ago, bmwking said: want your headlights to stop dimming? go led. https://www.amazon.com/OPT7-Headlight-Bulbs-Clear-Arc-Beam/dp/B00VNBDWPK/ref=sr_1_1?ie=UTF8&qid=1458508907&sr=8-1&keywords=OPT7+H11 probably time for an upgrade on the old yellow lights anyway I'd do this in a heartbeat if it wasn't for the bad reviews on LEDs in these headlight housings. Something about light beam scatter and what not. Subs don't hit when powered by cheap amps!
ToNasty Posted December 2, 2018 Report Posted December 2, 2018 For the bulb swap. Id go with morimoto ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
bmwking Posted December 2, 2018 Report Posted December 2, 2018 11 hours ago, TezasBassBox said: Right on. I'll put those on at the first of the list. This^^^ is what I don't get. With my older vehicles swapping the alternator and battery/ies cured this prob. Why not now? I'd do this in a heartbeat if it wasn't for the bad reviews on LEDs in these headlight housings. Something about light beam scatter and what not. ah you must have the reflector housings then. if it wasnt $300 to upgrade to the ltz projector style housing i'd say go for both. but spending nearly ~$400 just to fix headlight dimming may not be your thing
