Small 4th order
Ayork
DiBo, once i installed the tnuts  i was committed and one did pop loose on install, but fixed the issue.
I had to take the driverside and passenger side seats (its all attached) up to get the box in so the room it takes up is decent. It sits currently behind driverside, that will change.
I got only maybe 10min of play time but it sounds decent for for only getting about 500watt per sub.
6 hours ago, Ayork said:
Does anyone know about rather to switch phase on the subs? Ive read to do that if they r inverted but i have them installed like normal thru the baffle.
If you subs are both facing the same direction, phase probably isn't going to matter much.  If you want to mess with it anyway, if the sub motors are in the ported side of the box just swap the wires coming from your amp going to your subs.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 1519 Guests (See full list)
