Single Voice Coil Impedance Adjustment
I'm currently trying to run an 18" DJ subwoofer in my car but it sits at 8ohms and is a single voice coil sub. Is there any way to lower the impedance to 4ohms by jumping a wire from the negative to positive terminal? Not sure if this will hurt my amp and/or sub. Thanks in advance!
What he said.
Electricity takes the path of least resistance. Your subwoofer is the load that connects the negative and positive output of the amplifier. By placing a jumper between the inputs on that single voice coil woofer, you've now created a new path with almost no resistance, which will more than likely place your amp into protect mode, if it doesn't damage it. Your only option is either buy a second matching woofer, or buy a different model with a lower DCR.
Do it, record the results for us.
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
