JL AUDIO 1000/1 clipping
back to car audio years later, and first ever jl audio amp owner so far have 1000/1 and four cvt 10" kickers, so my ? is what causes clipping? low voltage? does the amp draw a lot of amps? subs start clipping at very low bass levels. should I get another battery or bigger alternator..?
Check ohms at the amp with a dmm make sure you are running the correct ohms.. I seen many times where people wire subs wrong.
Maybe your gain is set too high.
I remember my first decent amp being a JL Audio 500/1. It was pretty current hungry but I had no major issues with clipping as long as I kept the gain at a conservative level of course.
I don’t think the voltage an amp sees effects what the clipping point is. That’s all a matter of recording level, signal voltage, gains, and any bass boost levels you use (which should be none)
Both signal voltage level into the amp and the amp gain setting contribute to clipping.
Clipping happens when the output voltage capability of the amp is exceeded. That happens when you try to drive it too high via either a high volume, high gain, or a song who's frequency mix is too high in some region (bass EQ'd high for example).
Recommendations: Flatten your EQ and turn off all "bass boost" options both on the deck and your amp. Using the highest volume you like to listen at and the music track you know hits especially hard, set your amp gain a little below the clipping point.
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
