Battery testing voltage?
Most battery’s are rated to be dead at 12v and have testing of around 12.9 so at 12.3 that’s almost dead lol,  if those resting voltage are after charging them I’d say both battery’s are bad or going bad.
Not sure if dif brands have dif resting voltages so it could be different.
XS recommends 12v batteries stay above 12.6 so 12.3 is in bad water depending on the brand
Select battery type (agm) place in charge mode, when charge is complete it will automatically go into maintain mode (pulsing green LED). *If the charger
has to provide its maximum maintain
current for a continuous 12 hour period,
it will go into abort mode (see Aborted
Charge section)*
Leave it in maintain for a day, then remove charger for a day, then check battery resting voltage with a multimeter
Charge section)*
Also the schumacher cant go to desulphate directly. Should I get a ctek  charger? Those can directly choose desulphate.
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
  • Who's Online   0 Members, 0 Anonymous, 1487 Guests (See full list)
