Using stock bose amp SPEAKER wire for b2 ref amp
I know this is a silly question but this will save a days worth of rewiring if i don't need to.
So i have a bose bypass harness, the harness is wired directly to all of my bose speakers(all being replaced by b2 ref 3 way). Heres the issue though, the leads that come out of the harness are 16-18g wire that connects into a LC7i. The b2 amp pushes out 125.4 @ 4 ohms and 325x4 @ 1 ohm.
If i keep the stock wiring, will i  be losing power?
Or should i just rewire all of it with my big spool of cca sky high 14/16g?
https://www.audioholics.com/audio-video-cables/speaker-cable-gauge
heres a read that might help.
if they aren’t super long runs you could get away with minimal loss but I’d say make sure your subs using 12/14 gauge direct from the amp atleast. If those wires are 16 gauge then I’d say you should be alright but 18 you may lose quite a bit
Wire Size
2 Ohms
4 Ohms
8 Ohms
22 Gauge
3 Feet
6 Feet
12 Feet
20 Gauge
5 Feet
10 Feet
20 Feet
18 Gauge
8 Feet
16 Feet
32 Feet
16 Gauge
12 Feet
24 Feet
48 Feet
14 Gauge
20 Feet
40 Feet
80 Feet*
12 Gauge
30 Feet
60 Feet*
120 Feet
10 Gauge
50 Feet
100 Feet*
200 Feet
59 minutes ago, slowfkncar said:
Wire Size
2 Ohms
4 Ohms
8 Ohms
22 Gauge
3 Feet
6 Feet
12 Feet
20 Gauge
5 Feet
10 Feet
20 Feet
18 Gauge
8 Feet
16 Feet
32 Feet
16 Gauge
12 Feet
24 Feet
48 Feet
14 Gauge
20 Feet
40 Feet
80 Feet*
12 Gauge
30 Feet
60 Feet*
120 Feet
10 Gauge
50 Feet
100 Feet*
200 Feet
Bingo. Looks like i won't need to rewire my truck. thank you.
On 3/7/2019 at 7:28 PM, ToNasty said:
I was wondering the same but i found out im fine     i didnt wamt to have to repin the door harness for new speaker wire. What a pain it would be
The only wire runs i needed to do was my tweeters that are inside my door, didnt want to splice into the speaker and i also wired my dash speakers. Supposedly theres a crossover in the kickpanel somewhere and i didn't want that to mess with it. Now i just need to figure out how i can get my chimes back.
  • Who's Online   1 Member, 0 Anonymous, 1509 Guests (See full list)
