Lithium help
23 hours ago, Rich Schenk said:
Was just going to make a wood box size of d3400 stain and polyurethane it and leave wires more or less how they our minus starting battery
You start this yet, I am curious how this works out because I am thinking of something similar but smaller scale - only a 4k amp on a 270 alt and 45 ah limitless lithium
No not yet limitless 70ah is still just sitting there will hopefully.
Start working on building that battery delete this weekend. Have to fix hood release cable and latch then hopefully work on that battery delete
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Limitless lithium 70ah!Limitless lithium 70ah!Limitless lithium 70ah!
On 3/22/2019 at 1:31 PM, realflow100 said:
lithium batteries should only be charged on lithium battery chargers meant to charge that specific battery type
And the charger should cut off automatically when its full. and you should be able to leave it on as long as you want until you want to use it. but the charger cuts off so its the same as unplugging it as soon as the charger reads the battery as full.
I recommend charge it up to full. once full unplug the charger and leave the battery sitting until you want to use it. lithium batteries keep their charge for years only losing a few percent
Can you set the "full" voltage amount? You say charge it until its full, but what determines "full"?  Each battery build can be different.
Was told by owner of limitless to put it on the limitless 25amp charger till it goes green then pull it off till I'm ready to install. Will hold voltage for about a year
  • Who's Online   0 Members, 0 Anonymous, 1105 Guests (See full list)
