Two SA12s on a Apocalypse AAK-4000.1D too much ?
Thinking of upgrading from a dc 2k to an Apocalypse AAK-4000.1D but wanting to keep my new SA12s subs. Wondering if they could take the power. Wiring at 1 ohm for now.
I think the 4k would be too much for a pair of the SA12's but you might be able to get away with...Possibly
Team MaxRetribution
Si Vis Pacem Parabellum
I’d turn the gain down maybe 4K for 3-4  12’s. I run 1k per 10inch SA and they take it but not anymore.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
3 SA12's @.67 would smash. I have 4x12's on 2 AAK40001D amps and I can't even get them stinky. These amps are more stable than powerful. They wake up @ .67 and .5. I had all 4 subs @.5 and they impressed a lot of people. Amp didn't even get warm at .5. these amps are soooooo nice!
That amp also probably puts out over rated power so like 4400-4600rms at 14.4v. You have to remember that.
I figured it’d be a lil much unless I turned the gain down a lot. Not sure if I could wire .5 ohm my electrical is only a 240 alt two batts about 125 ah of agm
Think I might be able to fit four 12s in my trunk but it’d have to be sealed or a 4th built in my trunk. (Civic coupe btw)
I really dig the bass knob and the amps themselves are pretty good looking. Seem to have a decent heat sink too, dual inputs already, and a remote in / out
Gp car audio posted a picture of the 4k doing [email protected] but started with a reactive load of .33
Not to mention a clipping limiter on the amp itself. Keeps thd under .5% iirc. Everything you mentioned about the amplifier makes the deaf bonce amps my top choice. Heat sink is thick and heavy, bass knob has temperature display ( amp thermals at 182°f) but I haven't had mine over 110° wired @.5 and it has a thermal protect light, regular protect light and clip light. I'm currently in the market for the new AAK-20000.1D ( TRUE 10K @12v flat!!) Coming in April. 18v stable @20k. 14.4 it does 12k and @16v it does 16k. BTW my amp required a 270 Mechman and 300ah of AGM to run @.5. I originally had the amplifier in my Maxima on one zv5 15 at half. Hope this helps
How was your voltage with a 270 and 300 ah of agm? I might be making a bigger bank in the back if I go for this
