PSU and car amp for home use?
I'm thinking of getting a 650W computer PSU single 12v rail and a 1000W RMS CEA rated at 2 ohms rockville amp mono amp to power some subs in my home.
I wont be running the amp or subs at max power. just around 400 to 500 watts RMS total power. the average when playing music will be much lower than that though. so the 650W computer PSU should be plenty
My subs are two 12-inch 4-ohm subwoofers
its these ones
https://www.amazon.com/gp/product/B072LX1DS8 Rockville dB14 amplifier (its been tested on the dyno)
and this PSU
https://www.amazon.com/gp/product/B078HJ2RCW
I want to know if the PSU can be run by hooking the green wire on it to a black one up if it'll stay on or i'll need a dummy load for 5v rail or something.
can I just bridge the green wire to a black wire on this psu? or is there a better PSU I should get instead?
or if someone can recommend me a better amp and power supply for cheaper or similar price please show me.
wont work with my subs. I have two 4-ohm subs. so i wouldn't be able to power them with that amp it only says 4ohms. and the subsonic filter is too high. my subs can hit down to 20hz easily
I also dont have any of the connectors that plate amp uses. but I already have RCA inputs and connectors
so I would have to buy cables for it too.
It sounds just like your wanting someone to agree with you.
Home wiring is very different than vehicle. This is why your idea is not a standard practice. Most home or commercial Audio runs higher ohm loads not to over heat the input voltage circuit. Plate Amplifiers love 8 to 16 ohm loads ...
I just want to know if theres a better deal I can find that will work with the subs I have. and be similar or less price than the ones ive picked. but i can only get stuff from amazon right now. cant get from ebay or other websites at the moment.
You will ultimately spend more trying to cram 12v gear into a home system.
There isn't a better deal.  Using car audio amps in a home audio environment is nearly always a convoluted and unreliable mess.
Plate amps are cheap up to about 250 watts, from there the Behringer pro audio amps offer a really good bang for the buck.  If you shop around you can probably find a 1000 watt Behringer amp for around $200 and you won't burn your house down.
Builds:
Most “BIG” home theater systems I’ve built had single driver sub bass systems on no more than 600w.
sub bass in home audio is much different than car audio
I mean... Hell... If you can find one of the old school crown xls5000s, they do rated power. Damn thing puts out a titch over 200v at the rails. It's a nasty bitch. Good luck not blowing your breakers LOL
  • Who's Online   0 Members, 0 Anonymous, 4094 Guests (See full list)
