Crown Vic Budget Build 2x Sundown LCS
Added some component speakers to the door and deadened them. Need to get some better components soon. Added a AGM up front and rear. 4 channel amp for the highs
Picked up a set of Morel Maximo 6's. These things are amazing and the mid bass is amazing. I came from a cheap pair of Rockford R165-S - these speakers aren't even close to 6.5". I still need to tune, etc. These are going to sound amazing for the money. Im running active. I had a problem with my tweeters hissing. I changed 4-channel amps, but it didnt fix it. I also changed grounds on my rear AGM battery with no luck. I may try ground the 4channel separate. I also purchased new 4 channel RCA. The hiss gets louder when adjusting the Gain up. Tell me what you think.
  • 3 weeks later...
I just ordered 2 Sundown SA-12 DVC 2ohm. My box I built is 4ft3 @32hz so I will be good with my box.  Hopefully they will arrive this week.  I did restore my headlights today. made a big difference
Before
After
15 minutes ago, ToNasty said:
Why did you order 2 ohm subs? You'll have to wire to 2 ohm or .5 ohm
Because I got them cheap
Received tracking from Sundown today. 60lbs!! Bought these for 109$ each shipped from sundown yard sale. Hopefully i dont have to recone...
The yard sale could mean a few different things.  They could need to be reconed. Or maybe they had coil rub from a shifted motor which then makes that sub useless
They do guarantee no shifted motors
I have ordered from the yardsale before with good luck. If not ill get a recone and be done
I’m running 2 yard sale 10’s now and they pound.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
Awesome! When did you order them and i guess no problems. Im running 2 LCS 12" and they pound
