  • Skar Audio SKv2-4500.1D Class D Monoblock Subwoofer Amplifier
  • Competition Grade Quality and Performance
  • Extremely Powerful and Highly Efficient Design
  • Peak Power at 1 Ohm: 7,400 Watts x 1 Channel (14.4v)
  • RMS Power at 1 Ohm: 4,500 Watts x 1 Channels (14.4v)
  • RMS Power at 2 Ohms: 2,800 Watts x 1 Channels (14.4v)
  • RMS Power at 4 Ohms: 1,500 Watts x 1 Channels (14.4v)
  • RMS Power at 2 Ohms (Strapped): 9,800 Watts x 1 Channel (14.4v)
  • Frequency Response: 15Hz - 270Hz
  • Working Voltage: 8.5V-18V
  • Signal-to-Noise Ratio (Sensitivity): 95dB
  • Efficiency @ 4 Ohms: 86%
  • Damping Factor: 200<
  • Low Level Input (Gain): 6V - 0.2mV
  • RCA Line Output: Yes
  • Low Pass Filter @ 24 dB Slope: 35Hz - 250Hz
  • Bass Boost @ 45 Hz: 0~9 dB
  • Subsonic Filter @ 24 dB Slope: 10Hz - 50Hz
  • Phase Shift: 0-180 Degrees
  • 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC)
  • LED Power & Protection Indicators
  • Master / Slave (Strappable): Yes
  • Fuse Rating: 450 Amps
  • Dual 1/0 Gauge Power and Ground Terminal Inputs (2 of each terminal)
  • Remote Level Control Knob Included
  • Dimensions: 650mm x 232mm x 62mm (L x W x H)
You may sell items in the appropriate forum after reaching the requirements to do so.
Items posted most have a price - i.e. no auction posts
Thanks for understanding and welcome to the forums :)
  • Thanks (+1 Rep) 1
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
