Enclosure help for 2 hertz hx250
Thumping
Hey guys hertz calls for about .7 cubes per sub before sub displacement tuned to 38 hertz, to me it seems like to small of a box tuned high?
Looking for sql just wondering if anyone has experience with these drivers and can point me in the right direction as for volume and port tuning?
thanks a lot
They are the hx250 single 4ohm coils, both will be run off Kenwood kac9106d 500rms a piece, so you figure sealed is the way to go? I was thinking of tuning lower just figured since they recommended tuning at 38 they’re was a reason for it
 how much lower and if I tune it lower should I Still use the recommended box size of 20.6 litres?
Depends on your end goal with these drivers.
if you want massive bass, you went with the wrong drivers all together.
If you want Sound Quality, enclosure design will depend on vehicle, and what high end setup you need to match up with.
My apologies for saying this, but “sql” doesn’t tell us jack shit about your goals ...
I'm not a enclosure designer, but sealed and ported will work well with those drivers.
give us as much info as you can with your complete system goals and we should be able to help better.
Fair enough I’ve had a re xxx, job w12gti and some kicker l7s getting older just wanted some nice clean subs with a decent amount of bass
system will consist of
factory head unit
helix dsp pro
hertz mpk 165 comps up front
hertz mpk coax in rear
hertz hdp4 for speakers
2-Hx250s in the trunk
and a Kenwood kac9106d for subs
car will be sound deadened
Hoping for a good clean system that can still hit lows for rap and what not
What type of vehicle are we working with here ???
  • Who's Online   0 Members, 0 Anonymous, 1450 Guests (See full list)
