better off contacting them directly
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
The user manual seems to indicate using a sine wave rather than music. Have you tried that? Admittedly I don't own one so I'm not familiar with typical behavior for these units
Tried both. I did music also so that I would at least have transients powerful enough so that I could achieve peaks that I knew for a fact, beyond any stretch of the imagination were more than an order of magnitude greater than .9 to 2 watts.
  • 1 year later...
Hey Robin were you able to figure out this issue I'm having the same problem
  • 8 months later...
I am having a similar problem where I am only seeing maybe 1-5 watts max when I know it should be more like 2000-2500 in any respective mode. And my other problem is that the meter always shows either 200.0 ohm or sometimes >200ohm when I have a 2ohm setup... Also the button response is sometimes non existent but this is the least of the issues. I have tried test tones and music, three different new batteries and two systems, all to no avail
Unfortunately I see VERY few answers or solutions to AMM-1 issues on this forum. This was the first use ever on this unit and I am extremely disappointed as I was over the moon  when it arrived last week from Sky High and overall just stoked to own a tool like this.
I am really hoping it is something I am doing wrong even though I have done it all exactly by the manual with many attempts.
I haven't seen that behavior out of my AMM-1 and I use it to measure both music and sign waves for real-time power and peak.
Maybe reach out to D'Amore Engineering for support: [email protected]
I know Steve Mead is pretty customer obsessed and I expect Tony and Juan are just as customer obsessed as Steve.  Hopefully they can get you sorted out.
  • Who's Online   0 Members, 0 Anonymous, 1472 Guests (See full list)
