shepherd92683 Posted May 27, 2019 Report Posted May 27, 2019 I’d like to keep the 2 ohm amp I have and not have to buy another 4 channel but I can’t find out if this is possible somehow. I’m seeing so far it’s not. 2017 Honda Accord Touring Build coming soon
Mike4068 Posted May 27, 2019 Report Posted May 27, 2019 You could use 2 channels and run a pair in parallel on each channel.
DiBo Posted May 27, 2019 Report Posted May 27, 2019 You can have 8-4ohm speakers on a single 4 channel amp. 2 per channel @2ohms.
White Lightning Posted May 27, 2019 Report Posted May 27, 2019 Are you talking about one mid driver per door ?? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
shepherd92683 Posted May 27, 2019 Author Report Posted May 27, 2019 To be more specific, what I have is a Boston gt2125. Wanting to run a pair of Skar components up front and a pair of Skar coaxials in the rear. All 4 ohms of course. Specs for amp on page 3 of the link. Looking to maximize power output to somewhat keep up with either 2 12’s or a 15 on a 4k. https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Boston-Acoustics-GT-275-Owners-Manual.pdf 2017 Honda Accord Touring Build coming soon
Masterbasser Posted May 27, 2019 Report Posted May 27, 2019 so ur running 2 ohms per channel basically. whats the problem? use google man seems like a non question Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
shepherd92683 Posted May 27, 2019 Author Report Posted May 27, 2019 14 minutes ago, Masterbasser said: so ur running 2 ohms per channel basically. whats the problem? use google man seems like a non question Is there a way to wire them mono to pull the 600 watts from the amp and not stereo at 400? That’s 50% more power and what I’m trying to achieve. 2017 Honda Accord Touring Build coming soon
White Lightning Posted May 27, 2019 Report Posted May 27, 2019 Personally, I run Boston drivers over Skar drivers any day. Just Saying also, dropping ohm loads on a class a/b amplifier will not make more power, just limit your tuning capabilities. you need to run the components on the front channels and the coax drivers on the rear channels. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
shepherd92683 Posted May 27, 2019 Author Report Posted May 27, 2019 45 minutes ago, White Lightning said: Personally, I run Boston drivers over Skar drivers any day. Just Saying also, dropping ohm loads on a class a/b amplifier will not make more power, just limit your tuning capabilities. you need to run the components on the front channels and the coax drivers on the rear channels. I prefer the Boston’s too. I had been running some Skar pa’s on a Boston 4100 and they were crazy loud, only so much sq of course. I will take your advice and run them both stereo on each channel. Thanks. 2017 Honda Accord Touring Build coming soon
FrmDaLeftCoast Posted July 30, 2019 Report Posted July 30, 2019 If I'm correct, the OP is asking a question that I've also been wondering. No trying to take over OP's post, but here you go. My amp Hifonics BRX 5000.5 4 ohm - 60 x 4 +475 2 ohm - 120 x 4 + 750 1 ohm - CH5: 1000 x 1 Mono Bridge @ 4 ohms - 240 x 2 My subwoofers (2 x DS18 Z10 Elite) are wired at 1 ohm. Speakers - Front - JBL GTO939 Rear - JBL GX963 Dash - Rockford Fosgate P132 *5 Channel Amp Each channel will be identified w/a letter. From left to right - A, B, C, D, E, F, G, H & the 5th channel is for the sub. This is what my little mind refuses to understand. Is it possible to use the amps full potential and push 120 x 4 or 240 x 2? If so, common sense tells me my only choice is 240 x 2 Bridged. Is that correct? If yes, for the 1st 4 channels. my wiring will have the 2 positives in one channel (A) and the 2 negatives in one channel (D). Next up would be the 4 remaining channels, which I'd basically do the same as i did previously. both positives wired to channel (E) and both negatives wired to channel (H). Am I correct, or does this comment have you shaking your head??? lol
