Krisztián Arnold Posted June 18, 2019 Author Report Posted June 18, 2019 Okay some updates inconnection with the checkup on the issues raised. I had some time today to run some quck tests, which are aimed to make a more accurate picture of the whole thing. So I tried to swap the batteries, and it performed as before, it is for sure now that those are still good. I also checked my connections, and the crimps, are still fine, I pulled on them, and the cable doesn't move or separate from the lug, so it is also a good sign. I had one battery terminal that is a bit more loose, than it should be, but after some clamp tests I still found, that it does not realy matter, since it is not so bad after all. Maybe I am going to get a new set of battery terminals. However I still does not know what causes this whole anomaly. Do you guys think, that separating them by a dual power input terminal will solve this for real? That is the only thing really I can think of at the moment.
Krisztián Arnold Posted June 18, 2019 Author Report Posted June 18, 2019 3 minutes ago, BassMunky said: Try desulphate first. Check crimps. Make sure it pure copper wire. Sand all connections again lugs and on frame I charge my AGMs with an intelligent charger, an they are maintained well. I take good care of them. I checked all my crimps, and the are in great shape. The wire I use is the KnuKoncepts Kolossus Flex cable, so I think I told you everything about the quality!
slowfkncar Posted June 18, 2019 Report Posted June 18, 2019 2 hours ago, Krisztián Arnold said: I charge my AGMs with an intelligent charger, an they are maintained well. I take good care of them. I checked all my crimps, and the are in great shape. The wire I use is the KnuKoncepts Kolossus Flex cable, so I think I told you everything about the quality! What amp are you using bro? A drawing or picture of the wiring could help here. Are you pulling 300a+ out of single 2/0's?
Krisztián Arnold Posted June 18, 2019 Author Report Posted June 18, 2019 19 minutes ago, slowfkncar said: What amp are you using bro? A drawing or picture of the wiring could help here. Are you pulling 300a+ out of single 2/0's? I am using a Hifonics BRX 2016.1D. Also I am not pulling any 300+ amps, plus I only have a single 1/0. So the wiring is plain and simple, I have 2 batteries in series, and from there the wire goes straight into the amplfier, through a 200A circuit braker.
slowfkncar Posted June 18, 2019 Report Posted June 18, 2019 2 hours ago, Krisztián Arnold said: I am using a Hifonics BRX 2016.1D. Also I am not pulling any 300+ amps, plus I only have a single 1/0. So the wiring is plain and simple, I have 2 batteries in series, and from there the wire goes straight into the amplfier, through a 200A circuit braker. Two 6v batteries? Or you meant 2 12v in parallel? One under the hood & one in the rear? Honestly a single 1/0 should be plenty for that amp, have you checked voltage at both battery terminals while playing at a moderate volume level?
Krisztián Arnold Posted June 19, 2019 Author Report Posted June 19, 2019 9 hours ago, slowfkncar said: Two 6v batteries? Or you meant 2 12v in parallel? One under the hood & one in the rear? Honestly a single 1/0 should be plenty for that amp, have you checked voltage at both battery terminals while playing at a moderate volume level? I meant I have two 12V batteries in parallel (sorry I meant to write that) so it is a total of 200AH. So this is why I do not understand what is happening with them. The voltage depends greatly on the charge level, but I think they are around 12.4-12.5 territory on half volume. What I have been thinking of lately, is maybe 1 battery is enough and the other is not used so much. But than there is the fact that they are in parallel so they should be used as one.
